Warrior Problems
Old Jul 23, 2004 | 11:38 AM
ronjon's Avatar
Default Warrior Problems
I have a 96 warrior and yesterday I washed it and the engine with gunk degreaser, i also took off the exhuast and repainted it along with a couple other parts. After putting everything back together I get no response from the atv when attempting to start it, the nuetral light won't even turn on- can anyone help ??????[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jul 23, 2004 | 11:46 AM
Lomax's Avatar
check your battery connections under the seat and follow them where they connect to the starter and ground. Make sure they didnt come loose.
Old Jul 23, 2004 | 11:59 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
maybe turning the key to the ON position might help...
Old Jul 23, 2004 | 12:01 PM
ElectricShift's Avatar
Oh yeah...Im sure thats the kind of reply he wanted ^^
Sounds like a loose connection to me also.
Old Jul 23, 2004 | 12:02 PM
Speedy2222's Avatar
maybe it was in gear?
Old Jul 23, 2004 | 02:21 PM
Gwinnwarrior's Avatar
check your kill switch, it wont do anything if the kill is turned to off.
Old Jul 23, 2004 | 02:23 PM
04Raptor350Guy's Avatar
I too would check for loose wires
Old Jul 23, 2004 | 03:23 PM
ronjon's Avatar
Before i go ahead and post on a forum I made checks on simple routines such as turning on the key i was looking for a more intellegent reply than that but thanks- to everyone else thanks for the help and i'll follow the power and ground wires- as for the starter is this what it would sound like iff the starter just up and died or would it at least make some sort of sound???
Old Jul 23, 2004 | 06:44 PM
Speedy2222's Avatar
i hate t osay this but i know ppl who have done it... sometimes it's the stuff we do alot we forget to do occaisonally...
Old Jul 23, 2004 | 11:58 PM
YFZ4502004's Avatar
hey man, i have an 03 warrior and it did that a few times. got nothing from the electrics. i will bet you a 1000 bucks that your fuse is blown. if you are facing the grab bar look to the left, you will probally see a round black tube pull that off, it is only rubber, and pull it apart. it goes into two pieces. you should have a spare fuse and switch the two. you will fire right up. i have no idea what causes it. some thimes i have been sitting in a parking lot and it happened or just overnight. who knows. something with the cylonide maybe.
