Ruby wont start
Old Jul 23, 2004 | 06:08 PM
snoyl's Avatar
Default Ruby wont start
[img]i/expressions/face-icon-small-happy.gif[/img]Hi all , I have a 03 Rubicon with 1000 miles . Been having a problem with the battery i thought. Sometimes it wont crank like the batterys dead, but now with the battery fully charged it cranks so slow like the batterys dead and then i need to reset the clock. i have checked all the connections, they look good. it starts first pull with the rope, runs great ,shifts fine, all modes, lites are brite. im just a dumb carpenter but i havent tried my hammer yet. Any help would be appreciated. THANKS
Old Jul 23, 2004 | 06:15 PM
400EXRiderJeff's Avatar
Looks like it's broken.
Old Jul 23, 2004 | 06:22 PM
See if you can start it by sticking a screwdriver between the positive and negative battery leads and touching both with it.
Old Jul 23, 2004 | 06:57 PM
mudblaster's Avatar
dont do that or you'll blow up your battery.
it sounds like your battery is week.
do you ride it lots or dose it sit for weeks at a time.
my freind has an 03 rubicon and he let it sit over the winter and in the spring it wouldent start.
so he charged it up and it did the same as yours it turned over very slowly so he put in a new battery and it works fine now.
seams it just dident have enuff juice even with a charge it seamed slow.
Old Jul 23, 2004 | 11:17 PM
snoyl's Avatar
[img]i/expressions/face-icon-small-happy.gif[/img]Seems its the battery after all. Only a year old. How are the 26" tires????
Old Jul 24, 2004 | 05:30 PM
mudblaster's Avatar
sweet.
they are a huge improvement over the stock ones.
the lift kid made a differance also.
back to the battery.
my freind got his in september and parked in november and when he tryed to start it in march it was dead as a door nail.
i've herd that if its gonna sit for more then a couple of weeks you should disconect the battery.
because it has a clock and and other things that cause a slow drain on the system.
Old Jul 24, 2004 | 05:42 PM
400EXRipper's Avatar
Ur lyin. Honda dont brake
Old Jul 24, 2004 | 08:41 PM
hondabuster's Avatar
Charge the battery up, and take it to autozone or napa and have them do a load test on it. Its not unusual to have a battery go bad , and only a year old.
You might want to look into a battery tender, they greatly extend the life of a battery, that doesnt see much use.
Old Jul 25, 2004 | 01:04 AM
mucky's Avatar
Hey dude I'm a mechanic and I've seen batteries die just sitting before they even get installed
its not uncommon for it to happen. also check all cables to make sure that you have good connections
and they are clean and that they're not damaged inside. good luck
Old Jul 25, 2004 | 09:14 AM
dzzy's Avatar
A motorcycle\atv battery is one of the few things that last longer the more you use it. If you aren't using the machine, or are using infrequently, you need to charge the battery every few weeks if the weather is hot, every five weeks or so in the winter (batteries discharge faster the warmer it is).
