6-stroke engine
Old Jul 24, 2004 | 10:24 PM
ZukZilla550's Avatar
Default 6-stroke engine
Can you believe it?It's from Beare Technologies-Innovative Engine Design.
Old Jul 24, 2004 | 10:25 PM
http://sixstroke.com/
Old Jul 24, 2004 | 10:28 PM
(1)The 6-stroke engine is fundamentally superior to the 4- stroke because the head is a net contributor to, and an integral part of the power generation within the engine, unlike a cam only absorbing power.
(2)The 6stroke is thermodynamically more efficient because the change in volume of the power stroke is greater than the intake, compression, & exhaust strokes.
(3)The compression ratio can be increased because of the absence of hot spots in the combustion chamber.
(4)The rate of change in volume during the critical combustion period is less than in a 4stroke.
(5)The absence of valves within the combustion chamber allows design freedom.
(6) A one-piece engine from crankshaft to upper shaft becomes feasible. No head gasket.
(7)Fewer components, 15 per cylinder compared to 40 for a 4-stroke. Therefore the cost of manufacture is much less.
(8)Can be fitted to standard engine blocks so the market is much larger than the OEM sector , also includes the retrofit aftermarket sector.
The engine has proven to be robust on the race track, & have significant advantages over 4-strokes
(1)The valving is desmodromic
(2)There are no valves to drop or bounce.
(3)The rev limit is only what the bottom end can stand.
(4)Gas flow on intake increase of 20%.
(5)No possibility of engine damage if the timing belt slips or snaps
(6)The reed valves are so close to the intake ports that their tips become the virtual port opening. This achieves variable port area & variable engine demand valve timing. The tips open late & small amounts with low throttle settings & open early & fully at full throttle
regards to all
Malbeare
Old Jul 24, 2004 | 10:32 PM
lapeerbanshee's Avatar
sounds weird.
Old Jul 24, 2004 | 10:39 PM
You should see the site,they have a simulation on how it work's.It look's to have 2 combustion chamber's,1 is 2-stroke and 1 is a 4-stroke.What the heck kind of pipe do ya put on that thing?
Old Jul 24, 2004 | 10:44 PM
i have no idea, good question, i cant stop thinking about that now.
Old Jul 24, 2004 | 10:52 PM
Yeah,kinda got my thinking going too.I just got to know how it perform's,is it Modable,what it would sound like piped.
Old Jul 24, 2004 | 11:06 PM
what would it sound like.....???
Old Jul 25, 2004 | 12:27 AM
NovaLT250R's Avatar
lol it would have a huge fatty pipe with a 4 stroke header attached to it...i dont like the sound of this new techonlighy lol...its just another type of engine for our 2 strokes to beat...
Old Jul 25, 2004 | 01:40 AM
Eceriderjbomb's Avatar
I would think it would be damn heavy
