YFZ 450 Glowing Head Pipe
Old Jul 24, 2004 | 11:28 PM
EssPsi's Avatar
Default YFZ 450 Glowing Head Pipe
I know this has been discussed but some people have said it is ok and some said the quad is running too lean. I just bought a 04 YFZ 450 and have been riding only twice....I put a Alba Pipe kit with k&n filter and jet kit when I went riding tonight my pipe was glowin bright bright red. Should I worry about it or not? Thanks.
Old Jul 24, 2004 | 11:53 PM
yamahatheonlyway's Avatar
my friends yz250f does that too, he has been ridin with it like that for quite a while now.... and his is bone stock, he hasnt had any problems with his bike either, so i would say its pobly fine
Old Jul 25, 2004 | 01:14 AM
clngabob's Avatar
Better to be on the rich side instead of lean. Buy a new spark plug & run your quad for about 30 min or so of real good riding then remove your plug & check the color. If it's white your running to lean, if i'ts tan to brown you'll be okay.
Old Jul 25, 2004 | 03:48 AM
RoostItUp's Avatar
If you put the pipe on you must rejet also, you most likly are on the lean side if you haven't. Try a 45 pilot 2.5 turns out. The headpipe will still glow but don't worry, it's normal to an extent.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sep 23, 2015 06:23 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
