kfx400 a-arms and carb question
Old Jul 25, 2004 | 03:46 PM
QuadWreck's Avatar
Default kfx400 a-arms and carb question
Hey wats up. enyways i own a 04 kfx400 and am looking at longer a-arms. i'v never put these on befor so i don't know. how does the linkage work like the stearing tie rods do they fit or do i have to extend them also or do they just bolt right up?? does it matter if i got +2 or +3??? i have and extended axel also. thxs. Also im about to invest into hot cams for it and heard the stock carb just kills the machien. So i would like to know wat size carb i could (should) use thxs for eny and all feedback.
Old Jul 26, 2004 | 04:54 AM
boomboom's Avatar
i run a 03 kfx 400 i am from australa so dont have many options when it comes to parts but i run 2.5 a arms wich made 200% difrents any biger and u would run in to problems on the trails the carby come off drz 400 whent strat on ( it has a main pump insted of a sucktion slide heaps more botem end
i put a vortex ignition on it and a bills pipe on it and i dont have two many problems smoking the yamahas but with a revers and a more reliebell motor
hop i helped go the kfx
Old Oct 24, 2004 | 07:09 PM
Mark2203's Avatar
If your a recreational rider, go with Lonestar +2 a-arms. Best all around and Lonestar is great stuff. (www.lsracing.com) You will get everything you need outside of stock to make it work except the longer brake lines. LSR sells those also. I would recommend upgrading the shocks also. If you are going to upgrade your cams, add the DRZE head and base gaskets and Kibble valve springs. Even though everybody seems to like to lean towards the FSR carb, I've been totally happy with the Edelbrock carb. Really easy to deal with and made a big difference when combined with the other upgrades and port job. I think FSR would be best if upgrading the bore size.
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
