Just install a 4 degree offset key and my P650 seems to be running hot
Old Jul 25, 2004 | 07:52 PM
Xrxman's Avatar
Default Just install a 4 degree offset key and my P650 seems to be running hot
Anyone have any ideas on this one, everything went well but my fan seems to running a lot more now and the bike just feels a lot hotter is this normal???
Old Jul 25, 2004 | 08:18 PM
Cuda440's Avatar
Any chance you put the key in backwards? Sounds like you retarted the timing instead of advancing it. Just my thoughts.
Old Jul 25, 2004 | 08:21 PM
Cuda440's Avatar
Does it run any better? It should be running better than before you put the key in. Maybe you have a air pocket in the cooling system.
Old Jul 26, 2004 | 12:09 AM
KISSSOFDEATH's Avatar
Cuda440 is right about the air pockets. When its cool remove the radiator cap and let it run for a bit. If the system has any air in it it should work its way out. You can also help it by tapping on the lines and jacking up the front to release any trapped air.
Old Jul 26, 2004 | 08:01 AM
Xrxman's Avatar
I definitely got it in right I checked before putting it back togther and it does seem to be a bit stronger
Old Jul 26, 2004 | 09:10 AM
SHOTGUN's Avatar
This is going to cause a stir but here goes.
I know everyone posts with the advance keys and dyna that your motor runs cooler...but infact when you advance your timeing, you are causeing that cyclinder to fire earlier which causes more heat in the head. When you retard the timing, it is fireing later and it causes more heat in the exchaust pipe.
Old Jul 26, 2004 | 09:19 AM
Shotgun, that shouldnt cause a stir. I didnt notice the fan running any less at all when I installed my DG3 or the 4 degree key. I never ran the Dyna CDI long enough to notice it.
Only thing that I can say 100% sure lowered my operating temps was the Moroso Header Wrap. My wife could also tell a big difference on her leg.
Old Jul 26, 2004 | 10:10 AM
Xrxman's Avatar
What is is the head wrap , I am always trying to find a way to run my bike a little cooler
Old Jul 26, 2004 | 10:32 AM
Click on this link, http://store.yahoo.com/hm-performance/80809.html or do a search in yahoo for Moroso header wrap and click on the top link.
You can see the wrap on my exhaust in my photos if you like.
MikeyBoyesq
Nov 27, 2020 02:44 PM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
Dieseltrash
Jun 1, 2015 06:53 AM
