Drag racing
Old Jul 25, 2004 | 11:13 PM
FMF's Avatar
FMF
Default Drag racing
I am going to be doing some drag racing. And this is the first Time I will be useing the stage Lights how do they work? I thank it is the PortATree Timeing set up
Old Jul 25, 2004 | 11:21 PM
rapturd's Avatar
Default Drag racing
the staging lights are just like they are on tv you got 2 sencers one is pre stage the other is stage when you hit the first one the pre stage will light up then move forward alittle and then both the pre stage and stage should be lit then when the other person does the same the lights should drop if it's a pro tree all yellows will light up then the green
Old Jul 26, 2004 | 12:06 AM
FMF's Avatar
FMF
Default Drag racing
Ok Thanks. It is a PortATree so it that the one that is all yellow and then Green
Old Jul 26, 2004 | 12:43 AM
Outlawlawndragster's Avatar
Default Drag racing
The tree can be set up to start you by the first yellows coming on for .500 of a sec then off and then 2nd and 3rd then green . If they are set up to run pro tree then all the yellows come on at once for .400 of a sec then they go off and green comes on .
If there using staging lights try to always be the first to the line to stage . This gives you plenty of time to get locked into the lights and get focused . When the second lane gets set the tree starts to sequence .
Robinhood
Dec 26, 2015 10:28 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Sep 1, 2015 01:45 AM
