Honda Rancher shifting question
Old Aug 14, 2000 | 05:06 PM
bigsky's Avatar
When I come to a complete stop with my Rancher I often can now downshift to the next lower gear without having to gently rock the atv back and forth. All I get is a (-) between gear numbers on the LCD. Is this common?
Old Aug 14, 2000 | 11:24 PM
snowshark's Avatar
Something doesn't sound right. While riding slam on the brakes & come to a complete stop from 20 mph or so & be in 4th gear. All I have to do is hit the down shift button several times & ready to roll in first.
The only time that I have seen "--" is if the quad is turned on in a gear besides neutral. A little rocking motion will fix it.
Old Aug 15, 2000 | 04:29 PM
reconrancher's Avatar
bigsky
mine does the same thing and so does a guy i ride with so i think its normal
later
Old Aug 17, 2000 | 12:33 AM
trxray's Avatar
The "--" is normal, it's just the sensor has not picked up the gears have meshed. Soon as you move a fraction of an inch the sensor picks up the info, and then it displays the gear your in.
Old Aug 17, 2000 | 02:24 PM
cartman308's Avatar
doesn't sound "normal" but there is no MAJOR prblem there. you may try adjusting your clutch. the owners manual will tell you how. it's pretty simple. plus when you are sitting still and trying to downshift, have your handes off the brakes so the quad can roll a bit. this may also help.
good luck with this
cart
Old Aug 29, 2000 | 03:12 AM
Rancher4x4ESLuvr's Avatar
nothings wrong, its just the sensor.
Cole Hadden
Jun 15, 2025 09:05 AM
Scottma518
Jul 16, 2015 09:19 PM
1966F100
Jul 12, 2015 03:08 AM
tporath
Jul 11, 2015 12:31 PM
Scottma518
Jul 10, 2015 12:42 AM
