lakota will not run unless in choke
Old Jul 26, 2004 | 11:10 PM
beerbq's Avatar
Default lakota will not run unless in choke
Hi I have a lakota 300 and it sat for a year and a half not my doing. I cleaned the carb and jets but it will not run unless it is choked. When it is running when i give it gas real quick it seems like it is bogging down, I have to give it gas slowly. Please help.
clayton oh beerbq[img]i/expressions/face-icon-small-sad.gif[/img]
Old Jul 27, 2004 | 12:05 AM
rolsmojave3's Avatar
i donno but my mojave did that all the time so i just threw the carb out and got a 36mm Mikuni RS and now i can fly it was only $136 from cycle works racing
Old Jul 27, 2004 | 12:06 AM
is the gas line clogged
Old Jul 27, 2004 | 12:19 AM
Chris142's Avatar
There is something plugging the main jet
Old Jul 29, 2004 | 06:32 PM
Illus's Avatar
Make sure your breather tube on the fuel cap is open too, I had a street bike that did that and I found out the fuel cap was not venting properly.
Old Jul 29, 2004 | 11:35 PM
MojaveMoron250's Avatar
It is not getting gas which means either somthing is plugging the line or the main jet, you might also want to see if the needle valve is functioning properly.
Old Jul 30, 2004 | 10:33 AM
beerbq's Avatar
I have pulled the carb apart again and found the jetpilot was clogged so I cleaned it out. The main jet is clean. All the jets look clean. When I pulled the pilot air screw out the little oring on the end stayed inthe carb. It looked fine to me as much as I could see. I didnt want to pull it out in case it ripped but I guess I have to now.
beerbq
Beeline08
Nov 11, 2016 04:00 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
