zilla 4 sale
stock bore
$3,000 OBO
new a-arm bearings
new axle bearings
new wheel bearings
new brake pads
new shifter shaft
new clutch cable
new primary drive x-ring chain kit
473 piece stainlees bolt kit
cascade block off plate
dg nerf bars
22"razor rears
engine ice coolant
i just went throught the whole motor, i had to replace a cracked case
i have an extra 87 tranny that will come with it
also extra crank bearings
only one thing wrong wit it
STORY:
i was riding in a field i started to slow down from full throttle, and the revs didnt come down. i let off the gas, pulled the clutch and hit the brakes and the engine was at a constant hight idle. then it wouldnt shut off, so i turned the gas off
i have been trying to figure out the problem for a couple days and now i just noticed that the choke fell off the carb.so im assuming that thats why it was reving high, it was suckin air in throught he choke. thats the only problem that i know of
could use some new stem bearings
contact me at tinl300ex@adelphia.net
or i will trade for a dirt bike yz125 or cr125
stock bore
$3,000 OBO
new a-arm bearings
new axle bearings
new wheel bearings
new brake pads
new shifter shaft
new clutch cable
dg nerf bars
22"razor rears
engine ice coolant
STORY:
Quadzilla Heritage
Sep 25, 2015 01:39 PM
