Starving for fuel?
Old Jul 27, 2004 | 10:20 PM
Kawibayou185's Avatar
Default Starving for fuel?
Well,went to ride my Bayou today,fired right up rode it for maybe 5 minutes when it suddenly dies? So try starting it and if I choke it it will run until I turn the choke off? It has a electric fuel pump, could I have a bad connection or a bad battery or should my motors genorator keep it going once the fourwheelers started? Any help would be appritiated. Brandon
Old Jul 28, 2004 | 01:01 AM
minimus's Avatar
Is there a fuel filter?
Old Jul 28, 2004 | 01:52 AM
I checked them and they were clean, I dont know whats wrong with it? Thanks for your reply.
Old Jul 28, 2004 | 08:36 AM
hitman1970's Avatar
Think you need to clean the carb. If it will run on choke untill you turn the choke off then the battery is not the problem. Drain the bowl on the carb then try it, you might get lucky. If that doesn't help you will have to remove and clean the carb.
Old Jul 28, 2004 | 09:00 AM
trx450's Avatar
check your tank and carb vent lines. My P-650's tank vent got packed with mud, and it ran way shi_ty!
Old Jul 28, 2004 | 02:19 PM
Ok ill look at the vent lines. I started cleaning the carb. this morning figured I might as well check over everything in it. Does anyone know much about these fuel pumps? Thanks for your replys ,also when you change your fourwheelers engine oil do you have to pprime the pickup tubes?
Old Jul 28, 2004 | 02:48 PM
trx450's Avatar
you don't have to prime an in-tank fuel pump. yours IS in-tank, right? I am only familiar with the big Priaries(V-Twins). You can test pump capacity/pressure by removing the fuel supply lie from the tank, and replacing it with a hose to a container that is graduated, so that you can measure flow. The fuel pump should run with the ign. key in the "RUN", I think. If it doesn't work, try starting/idling the engine. Engine MAY have to be running to energize fuel pump circuit.
Old Jul 28, 2004 | 03:33 PM
hondabuster's Avatar
If it will run with the choke but dies, when its not on, then its not the fuel pump. Sounds like a plugged pilot jet.
Old Jul 28, 2004 | 07:20 PM
The fuel pump is mounted to the frame? Im unfimiliar with these four wheelers.I cleaned the fourwheelers carb. everything looked clean, I gave it a good gas bath. New spark plug full tank of gas fired right up.Thanks for your replys!
ltrmc02
Aug 22, 2021 02:34 PM
SureCanUSA
Sep 14, 2015 09:57 AM
PrairieDog126
Sep 12, 2015 06:53 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
