03 360 Problem...
Old Jul 30, 2004 | 01:54 PM
sportbikenut2's Avatar
Default 03 360 Problem...
My 360 has a bad vibration sound coming from what it sounds like perhaps the motor at a certain rpm range. Probably mid throttle.. It goes away once u drop below or above that range. Kinda thought at first like maybe the aftermarket skid plate was rattling up against the frame or something but everything seems to be tight down there. Its not a quiet noise by no means. Anyone else had this problem and if so perhaps a fix?
Old Jul 30, 2004 | 02:52 PM
Uinthas's Avatar
sure it's not coming from the belt houseing?? Mine makes a "winding up" noise, drive's me nuts[img]i/expressions/face-icon-small-disgusted.gif[/img] I also has a bad vibration around that throttle range, turned out to be the exhaust rateling, so I just took a big clamp & secured it up where it was ratteling (right by the gas pecock)
Old Jul 30, 2004 | 03:07 PM
OleManMoses's Avatar
my richochet skid plate vibrated like a banshee after install----cut a couple of bungee cord peices and loosened bolts, then retightened with bungee stuffed in there
Greenbaron
Aug 8, 2019 08:25 PM
barbarryan
May 15, 2008 12:50 AM
rebeltaz
May 12, 2008 12:11 AM
aceisback
May 11, 2008 10:04 AM
PEGGYSUE
Jan 30, 2004 11:29 AM
