jetting question
Old Jul 30, 2004 | 02:56 PM
Aaran's Avatar
Default jetting question
i have a hmf slip on, no air box lid and a soon to come notoil air filter. what do u suggest for jetting. the carb is stock except for a 165 mj. is it okay to stay with the 165 or not?
Old Jul 31, 2004 | 02:51 PM
Aaran's Avatar
anyone???
Old Aug 1, 2004 | 08:34 AM
MBrooks420's Avatar
It all depends. Does it run rich/lean at all not? You may have to go up a size. I'd run it for a while and check the plug.(After the motor has colled of course)
Old Aug 1, 2004 | 11:58 AM
Marky522's Avatar
if you just want a general idea if you have to change the jetting let it warm up and run it wide open for a minute then pull the clutch and let it coast to a stop, pull your plug, if its white your lean if its blackyour rich. this is just to give you a good idea.
Mark
Old Aug 1, 2004 | 12:03 PM
MBrooks420's Avatar
I'd let the head cool before pulling he plug, to let the aluminum cool and contract.
Old Aug 1, 2004 | 12:36 PM
Aaran's Avatar
also what other things could i change in my carb (needle, etc.) that would make it run better or isnt that necessary
Old Aug 1, 2004 | 03:52 PM
MBrooks420's Avatar
From what I understand the pilot jet is for idle to 1/4 throttle, the needle is for 1/4 to 1/2, and after that it's all main jet. This may not be 100% correct.
Cole Hadden
Jun 15, 2025 09:05 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
