240 kit
Old Jul 30, 2004 | 05:24 PM
sickblaster00's Avatar
Default 240 kit
if i get a 240 kit do i need a larger carb???? also do i need a pipe and silencer?? i am confused on what i need to get for this kit thank you for the help guys
Old Jul 30, 2004 | 05:37 PM
02blasterguy's Avatar
Default 240 kit
Yes you will need a bigger carb., and several different things.The dg pipe is basically a stock replacement pipe.Basically what you want is(CT Racing Sonic Complete Package:Comes with... cylinder, head, piston/rings, wrist pin, circlips, gaskets, reed cage, intake boot, 36mm PWK pre-jetted carburetor, CT pipe and silencer).Its about 800 dollers, and I'm pretty sure its the best kit out there.If you dont want to spend that muce you may want to look into hollywood dirt productions 240 kit(thats what i'm looking at),its about 500-600 for the kit.Theres also vitos big bore 240.But looking at your upgrades the ct sonic kit would probably be the best.
Old Jul 30, 2004 | 05:38 PM
Default 240 kit
Oh, and when you do all this engine work you want to get a longer swingarm to keep the front end down.
