Banshee Issues
Old Aug 15, 2000 | 01:11 PM
geek's Avatar
Ok so I am new at the whole 2-stroke thing but have learned a lot lately...
here is my problem. I just rebuilt the Top-end of my banshee it is now bored 30 over, I had 290 main jets and replaced with 310 since I was running super lean... This seems to have been the trick. Any comments ??
Also one cylinder does not seem to be firing the same as the other ? I typically am running at sea level. Plus I notice that one seems to blow a little more smoke then the other...
I think most of this is related to the carbs not being synched or something... One Carb Top is slightly damaged from previous owner trying to use a set of pliers to get it off So I dont think that one is gettng a tight seal...
Old Aug 15, 2000 | 03:35 PM
DunePilot858's Avatar
The carb top not sealing is bad news... I would get a tors removal kit from toomey. Replace those carb tops before you ride other wise you could be doing another topend really soon.
Old Aug 15, 2000 | 07:11 PM
geek's Avatar
Figured as much ...
The TORS has already been moved...
I think I am just going to get new Carbs
Mikuni ? Keihin ? any suggestions ??
Thanks
Old Aug 15, 2000 | 07:50 PM
Veeshman's Avatar
I run the Mikuni 28mm flatslides. They are great. Much better throttle response and bottom end.
Cole Hadden
Jun 15, 2025 09:05 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
