dg key problems
Old Aug 1, 2004 | 12:55 AM
rubicon20032003's Avatar
Default dg key expolled
I was racing a brute tonight on the second race my quad was making a noise on the flywheel side and then I pulled the cover the key was in a couple of pieces.I hope the rest went in the oil filter.So beware and watch if you have the same problem.If anyone has a stock key you want to sale.I need one for grass drags this weekend.I'll send money first thing monday
Old Aug 1, 2004 | 05:15 AM
schl48a's Avatar
Default dg key problems
it's a woodruff key so most lawn mower shops should have them. i've gone threw about 5 of them.( STOCK AND CUT).
Old Aug 1, 2004 | 11:00 AM
dosthoff's Avatar
If the flywheel is properly torqued and the taper seated on the crank, there shouldn't be much stress on the key. Have you looked inside yet? Did it score the crank end at all? I've got a cut key in my KFX, so now I am nervous about it breaking. I never dreamed they would shear off when the flywheel is seated on a taper like it is.
Old Aug 1, 2004 | 02:14 PM
It was torquerd right.There was no damage to the crank.That was good .Does anyone know the size i need.From the lawnmover shop.Do the come in different sizes?
Old Aug 1, 2004 | 02:36 PM
KISSSOFDEATH's Avatar
Old Aug 1, 2004 | 06:40 PM
schl48a's Avatar
i don't know the part number. i took my two broken pieces in and they matched it up.
Old Aug 1, 2004 | 06:48 PM
It was torqued to specs.It didn't mess anything up.The key wasn't very tight when i installed it.I put a new key in today.It fit alought better .Runs better
Old Aug 1, 2004 | 07:13 PM
Glad you got it up and running again. That loosness could have been the problem??
Old Aug 1, 2004 | 11:33 PM
travelor's Avatar
Was it a 4 or 6 degree? Would a 6 be worse for breaking? Would a 6 be worth putting in instead of 4?Glad you got it going right away? The big question, did you beat the brute??????
Old Aug 2, 2004 | 07:26 AM
travelor, not sure who your question is for but I have a 4 degree key in mine. The 6 degree should be just as reliable as the 4. I havent raced the BF since the key install but I can tell you it will take a lot more than the 4 degree key for me to make up 3 atv lengths.
