overheated p650 knocks now
Old Aug 1, 2004 | 12:44 PM
wildrides's Avatar
Default overheated p650 knocks now
Old Aug 1, 2004 | 11:38 PM
travelor's Avatar
How long did you ride it hot? I am having trouble with boiling out antfreeze.
Old Aug 2, 2004 | 01:54 AM
wildrides's Avatar
about 2 hours it was ridden while overheating
Old Aug 2, 2004 | 02:22 AM
MURDR's Avatar
If your hear a knock your screwed. Engine overhaul. OR it may be your oil pump if they have one. GOOD LUCK.
Old Aug 2, 2004 | 02:37 AM
hondabuster's Avatar
Hopefully the worst that happened, is a blown head gasket. A leak down test should tell if thats happened. Are you losing antifreeze? can you smell antifreeze when its running?
Old Aug 3, 2004 | 09:39 PM
bushpusher's Avatar
my bet is that you collaspsed a piston(skirt on piston shrunk) is the knock worse when cold?
Old Aug 4, 2004 | 01:49 AM
wildrides's Avatar
yes it is eating antifreeze but I don't smell antifreeze. haven't done a leak down test yet.
Have not ran it long enough to warm up
Old Aug 4, 2004 | 01:53 AM
wildrides's Avatar
travelor
does your temp light come on? My buddy has a twin peaks that light came on all the time if radiator was not totally clean front and back. Used redline water wetter and his light has not come on once even with dirty radiater cruising around park at 5 mph
Old Aug 5, 2004 | 01:31 AM
travelor's Avatar
Thanks wildrides, I should try that water wetter. Where do you find that stuff? My radiator is clean. No light has showed up but once the temp sign was on, hard to read because no color or flashing to draw your attention. The bike loses antifreeze out the overflow without getting too hot anymore.
Old Aug 5, 2004 | 02:39 AM
wildrides's Avatar
redline from summitracing.com
http://store.summitracing.com/defaul...G&N=120+400236
u should check or change the rad. cap and make sure the rad. neck has not been warped
Do you actually see fluid come out the overflow
might as well order some header wrap from summit too
