Installed hmf echo pipe on 700
Old Aug 1, 2004 | 05:37 PM
travelor's Avatar
Default Installed hmf echo pipe on 700
This thing is almost as loud as the nyroc muffler mod. Power may be a bit better. At least I got my spark arrester.
Old Aug 2, 2004 | 12:22 AM
travelor's Avatar
I am having trouble with boiling out antifreeze. Could the pipe do this? It was fine with the pipe mod. Maybe it was just hotter outside. 85 degrees.
Old Aug 2, 2004 | 02:26 AM
cartman308's Avatar
it the pipe leaned you out a bunch then you could be running way to hot. Check your plugs. if you lean jet up to 142/145 or 145/148.
Old Aug 2, 2004 | 01:13 PM
Marylandatv's Avatar
If your jetted to HMF specks you should be OK? (The Exhaust should have come with jetts and instructions from HMF?) Something that is over looked and also the #1 reason for the Quads to run hot or boil over is a dirty radiator? You really need to get in there with a hose and spend 5 or 10 mins just cleaning that baby from both ends! and IMO a Car wash will not work as well as just getting the garden hose in them corners! Thats one of the reasons I tossed the inside black plastic myself along with allowing better air flow around the engine and radiator. ~coop
www.MarylandATV.com
Prairie 700
Team Green Plastic
Progressive Springs
OMF Beadlocks
Maxxis Big Horns
Dyna CDI
EPI Pink Spring
Twin Air Filter
HMF Penland Exhaust
And a Bunch of other Toyz
Old Aug 2, 2004 | 02:31 PM
tuffEnuf's Avatar
Travelor
How do you like the Dalton Purple & hows the performance on the trails? Have you compared it to the EPI Red? I was Thinking about trying the Hotseat Purple to see if it would make my setup performed better.
TuffEnuff[img]i/expressions/face-icon-small-cool.gif[/img]
Old Aug 3, 2004 | 01:58 AM
travelor's Avatar
Thanks for the replys, The pipe didn't require a jet change and I am way rich according to the conversion chart. Like 152 and 155 if using keihin jets. I think the pipe mod had better flow as this is restricting more. The radiator is clean. It seems to leak out after i shut it down. As for my springs I didn't really try anything except the dalton secondary spring, was wondering about the epi, I think I will put my blue primary back in. I wonder if my system could be air locked?I fill the radiator and side bottle each time, maybe used 2 quarts in 20 miles filling 3 times.
ReconBayou
Oct 31, 2022 05:37 PM
mrtidy
Feb 3, 2016 05:00 PM
2many2ride
Sep 27, 2015 04:35 AM
greg86hd
Sep 16, 2015 12:32 AM
