400ex shock problems?
Old Aug 15, 2000 | 10:58 PM
trx270r's Avatar
my 400ex(1999) has blown both front stock shocks. I now have works, was wondering if anyone else has had this problem.
Old Aug 15, 2000 | 11:03 PM
gripnripn's Avatar
I never blew the shocks. But I broke the a-arm lets' the bottom shock mount off. Needless to say I now have +2 a-arms and tcs shocks that will arrive tomorrow
Old Aug 18, 2000 | 06:57 PM
bigal's Avatar
Mine weren't leaking oil yet but compared to a new machine they were junk, so I got Works. but mine is just over 2 years old now, and I'm a little heavy for the way I ride.
Old Aug 18, 2000 | 07:21 PM
c400ex1234's Avatar
hmmm..... i weigh 170, and i jump pretty high on stock suspension... what do you think my jumping limits should be?? like in feet??
Old Aug 18, 2000 | 11:27 PM
hakmazter's Avatar
13 ft up if you have a downside to land on. If you land on flat, you will probably start to bottom out around the 5-7 ft mark.
Old Aug 19, 2000 | 10:44 AM
400exalltheway's Avatar
i would want a landing ramp also flat landings are ALOT HARDER
Old Aug 19, 2000 | 12:43 PM
c400ex1234's Avatar
yeah 13 is around what i get with a landing, but i don't bottom out, and i do bottom out at 6 feet on flat..
I just didn't want to break my shocks..
Old Aug 26, 2000 | 10:03 PM
Skunky's Avatar
Take it from experence... loss those shocks if you do anything more then rec riding.. I cased it on a 40 ft double, shocks bottomed, casing the force of the landing into my right wrist.. dislocated 3 bones...
00400EX, WB CDI, FMF PowerCore 4-2, FMF PowerBomb Header (releases ???), K&N AirFilter w/prefilter, UNI Filter, no air box lid, Dynojet kit 165Main, 20x11x8 Shreaders in the rear, ITP .190 8" rear rims, FMF BFB 909 Bars (Pro Taper), Pro Design Power Shifter, DG Front Bumber, DG Full Skid Plate, DG Rear Skid Plate, DG Nerf Bars, Outerwear Shock Covers, Renthal Drive Train (Renthal 14 tooth up front, Renthal ultra light 39 tooth in rear, Renthal 520 R-1 Works Chain) Pro Design Kill Switch, Skat-Trak 20x11-9 8 paddle, RPM +2 a-arms, RPM +2 Swingarm (both powdered red), Durablue +2 eliminator rear axle, Durablue axle carrier, Durablue Anti-Fade Brake Carrier/Lock Nut, +4 Custom Braided Stainless Steel Brake lines, WB BP Block Off
Reactant
Mar 30, 2022 02:08 AM
Captjay
Jul 23, 2015 12:33 PM
95wolv
Jul 21, 2015 12:25 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jkfx400P
Jul 6, 2015 10:04 AM
