carb specs and other info needed for '89 Breeze
Old Aug 5, 2004 | 01:52 PM
confusedbuyer's Avatar
Default carb specs and other info needed for '89 Breeze
I posted earlier as a '95 Breeze... turns out it's an '89 (after checking VIN).
1)How many turns out is the air/fuel screw supposed to be?
2)Float height?
3)Anything to maintain or check inside the belt cover? Mine sounds a little rattle-ly in there.
4)Recommended plug and gap.
5)what's the deal with the foam filter under the front fender cover? Do you just clean it, or do you oil it?The air goes into the belt area.
6)WHat oil do you use and capacity.
7)Is there a tranny oil as well (second drain plug?). If so, what weight, and capacity?
Anything else peculiar to these, or info/maintenance you think I should know?
Thanks guys.
Old Aug 8, 2004 | 03:17 AM
anyone?
ALso, it sounds like it has a miss when it's idling, what could that be from?
Old Sep 20, 2004 | 02:34 PM
I'll answer my own Q in case someone else does a word search and needs this info.
1) 2 1/2
2)21.8mm-22.8mm
3)just the belt????
4)CR7HSA, can't remember gap. .25 MM ?
5)I just cleaned mine, no oil. not sure if that's right or wrong.
6)I used 10-40, but Yamaha recommended anything from 5W30 to 20W40, depending where you are.
Capacity is 1.25 L or quarts.
7)yes, there is tranny oil. I used 10W40. .6L/quart capacity. there is a middle screw you remove. once oil drips out, you're full.
Valves need adjusting, and they recommend you check ignition timing, altho not much you can do to adjust timing.
chain drive, so that needs adjusting and maintenance. on left side, the tension adjustment bolt wants to wander. I drilled a small detent into the large, wide washer, and now that seems to hold bolt in correct position.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Dieseltrash
Jun 6, 2015 09:53 PM
cornermike
May 28, 2015 09:47 AM
psilman
May 26, 2015 09:40 AM
