will 24-9-11 rear tire fit on 23-8-11 front rim?
Old Aug 16, 2000 | 10:34 AM
Frank300's Avatar
Help guys, trying to decide on new tires and wanting to go 1 size bigger in the front and rear. Will this combination work for the front and can I increase the rear to a 25-10-11? Thanks for the help.
Old Aug 16, 2000 | 11:11 AM
exlax250x's Avatar
in theroy yes it would work but you are gonna have to watch out for tire clearence when turning and not to mention how it will look
Old Aug 16, 2000 | 12:21 PM
snowshark's Avatar
It should work, going up one inch you shouldn't rub your fender. One inch wider is not a problem, either.
Old Aug 16, 2000 | 01:14 PM
Frank300's Avatar
How much wider can I go on the stock rim, and how much wider is too wide?
Old Aug 16, 2000 | 11:44 PM
puddding's Avatar
width depends on the tire in question and the manufacturers ruler.....some are wider than others, taller than others, and the all display the same tire size
eg it had 23-8-11 otshus on the front, then put 23-8-11 maxxis surtraks on the front....the surtraks were a wider tire
plus one inch in width is ok......rubbing the inside spats (under the mud guards can occurr), but no major hassle to fix.....just remember you have to have the power to turn the wheels as well.....bigger, doesn't all ways mean better
ride hard
Old Aug 20, 2000 | 07:16 PM
paddler's Avatar
dont worry about it ....i put 25-10-11 mudrunners on my 300 and it works just fine.
Reactant
Mar 30, 2022 02:08 AM
JackTheKing
Jul 14, 2015 09:09 PM
rcappie4
Jul 10, 2015 04:54 PM
cSchwartz
Jul 9, 2015 02:40 PM
Rider252
Jul 6, 2015 03:37 PM
