Need new jets or not??
Old Aug 5, 2004 | 09:22 PM
grizz4life's Avatar
Default Need new jets or not??
Just bought a new 2005 grizz 660 and am planning to go trail riding in colorado. Elevation will be around 8 - 10 thousand feet. I dont want to get out there and and have it run doggy. I am up for any suggestions thanks
Old Aug 5, 2004 | 09:26 PM
ItalianStallion's Avatar
You may only have to remove your air box lid ....It may still run a bit fat but it may run just rite...If you have to jet..I usually go down 4 sizes
Old Aug 5, 2004 | 09:46 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
This works great! Install a couple of TPI Valves in your airbox lid. http://www.thunderproducts.com/tpi_valve.htm
Open them up for more air as you ascend, and close them again as you descend (and above 10,000 ft., just pull the airbox lid completely off). It's an INSTANT REJET!
I have my bikes jetted for the low desert (sea level or even below!), but I also ride up into my local mountains and the Sierras at over 10,000 ft. So, this gives me the go-anywhere versitility that I need.
Old Aug 5, 2004 | 10:13 PM
grizz4life's Avatar
Thanks for the info, sounds easy, but... how do i know what valves to install
Old Aug 6, 2004 | 12:07 AM
Red Rider
I use two of the "low boy" valves, on each bike. You gradually open them, little by little, as you go up in altitude, and close them again as you go down. DO NOT forget to close them as you descend! That will make you lean, which is bad for your engine.
Old Aug 6, 2004 | 03:50 AM
18000dollarbanshee's Avatar
i would say re jet is the way to go its easy and it will make ur engine run consistant instead of knockin alot
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
