2wd 4wd flashing
you have to count the seconds between the flashing
the chart in the manual shows each light staying on for .5, 1, or 2 sec. depending on what is wrong. a full cycle is double the length of a flash, i.e. if both were malfunctioning then the cycle would be 4sec. long (the time it takes the 4wd and 2wd to alternate)
if it is flashing every:
.5 sec = 4wd
1 sec = engine brake actuator
2 sec. = both
.5 sec = 4wd
2 sec. = both
Try pulling the fuses, cleaning them, and reinstalling with some dielectric grease. The fuse block has a tendency to collect mud and dust. Once the KEBC fuse gets dirty it cuts the circuit and creates the flashing.
speedbuff
13
Nov 11, 2020 10:16 AM
