sounds like rocks!
Old Aug 7, 2004 | 05:39 PM
Hez's Avatar
Hez
Default sounds like rocks!
This is something I just noticed. I've only ridden my new DS for about 3 hrs. When it is idleing it sounds as if the valves are going to drop into the cylinder. What the heck!, when i rev it up it sounds fine but at idle it sounds like rocks in the valves!!
Any IDEAS???
Thanks
Hez
Old Aug 7, 2004 | 05:45 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
was the choke on?
Old Aug 7, 2004 | 05:46 PM
Hez's Avatar
Hez
not at that point, this was after i realized the choke situation and turned it OFF.
Old Aug 7, 2004 | 06:36 PM
SANDMAN430's Avatar
i'm sure you checked the oil level?
Old Aug 7, 2004 | 09:48 PM
DuneRider650's Avatar
I ride a little here and there......
i have the same sound i think you are refering to at low rpm it makes a clink clang noise, but ive had mine for about 3 months now runs fine so i wouldnt worry about it to much
Old Aug 7, 2004 | 10:47 PM
thebigshow's Avatar
ive got an 03 and it did it when it was new and after i had tvi rebuild it, it made the same noise.
Old Aug 8, 2004 | 04:56 AM
Hez's Avatar
Hez
Ok, sounds like its nothing to worry about.....
Thanks guys!
Old Aug 8, 2004 | 12:45 PM
SANDMAN430's Avatar
seems the engine makes a little noise at idle, but you might want to keep a eye on your timing chain tensioner.
Old Aug 8, 2004 | 08:22 PM
TheOz's Avatar
My 04X has made a little engine nose at idle since day one. Machine has run kick a$$ since I've had it. Probably due for a valve ajustment soon. I just don't know where to take it to make sure it's done just right.
Old Aug 8, 2004 | 08:52 PM
SANDMAN430's Avatar
do it yourself it's easy and then you will never have to worry about it.
