Buying an ATV Questions and suggestions about what to buy, financing, insurance, etc.
Which ATV?!?
Old Aug 9, 2004 | 01:02 PM
mudwarrior86's Avatar
Default Best out of four!
Ok. I've narrowed my choices down to 4 ATV's. Which one do you think would fit me best (I want something to play with and have fun on in the mud)? It doesn't matter if they are semi-auto. or auto. In short, what do you think would be better of them all if you don't want to read it lol. (Bruin 350 4x4, Prairie 360 4x4, Kodiak 400 Auto. 4x4, Big Bear 400 4x4, or the Eiger 400 4x4 Manual)
They are the:
Bruin 350 4x4 = $4,395
Pros:2wd/4wd, Automatic, heard belt wont slip as much, Reverse, 9.7' of ground clearance, and only 538 lbs.
Cons: None so far
Prairie 360 4x4 = $4,695
Pros:20 more cc's (not gonna tell much difference though), Automatic, high/low range, 2wd/4wd, Front Differential Control, and a light incase the belt slips alerting you that it happened
Cons:7.7" of ground clearance, 604 lbs.!!!, bogging problems
Big Bear 400 4x4 = $4,595
Pros:386 cc's, cheaper than Prairie, semi-auto. w/ reverse, 2wd/4wd, 9.7" of ground clearance, 4 gallon gas tank (compared to others its bigger), and 556 lbs.
Cons: None so far
Kodiak 400 Auto. 4x4 = $5095
Pros:Independent Rear Suspension (IRS), 401 cc's, 2wd/4wd, 10.8" ground clearance, 4.0 gallon gas tank, 578 lbs.
Cons: No low range (but doesn't mean I would need it does it?)
Eiger 400 4x4 Manual = $4,695
Pros:376 cc's, semi-auto., high/low range, reverse, 9.3" ground clearance, 2wd/4wd, 4.0 gallon gas tank, 577 lbs.
Cons: None so far
Ok, tell me what you think. PLEASE HELP
Old Aug 9, 2004 | 01:13 PM
TrailBlazerguy250's Avatar
I would go w/ a kodiak
Old Aug 9, 2004 | 06:46 PM
SEMO's Avatar
Default Which ATV?!?
honda rancher.
