Left front wheel pushed backwards
Old Aug 9, 2004 | 09:47 PM
Wax's Avatar
Wax
Default Left front wheel pushed backwards
I hit a tree now my wheel is pushed back an inch farther than the other side, causing my tire to appear tilted...can I fix this with a come-a-long or is this a problem for the dealer????
help,
Wax
Old Aug 9, 2004 | 10:23 PM
quadduck's Avatar
Was this on your Eiger? ouuuuuuuch! Dont take it to the dealer and don't use a come a long. Take it to a local weld and fab shop. Here in the pacific nw most the shops are use to fabing and fix'n logging equipment Which can be tricky. Ask around and find one in your area . If they can' fix it then go on ebay but they will be able to most likely. Unless you bent a tie rod., then you can fix that, describe which way the tire is pointing.
Old Aug 9, 2004 | 10:43 PM
Wax's Avatar
Wax
When looking at the front, the tire is tilted ....top in....bottom out. still rides nice, all hardware is tight but it is very noticable and can't be good for my tire,,, 4wd seems to be unaffected. I'm bummin' out here...
Wax
Old Aug 9, 2004 | 10:46 PM
Stainless's Avatar
I bent my a-arm on my vinson which made my wheel do that too. Take a real close look at it and see if it is twisted. I took mine off and bent in back into shape pretty easily.
Old Aug 9, 2004 | 11:36 PM
quadduck's Avatar
Yeah what stainless said and the condition of your front wheel would be the camber being negative and not the tierod which would be the toe but if you bent it that bad you could have bent the tie rods and the frame . Also remeber the more metal gets bent the weaker it gets. good luck
old quads
Aug 13, 2015 10:32 AM
traumajunkie
Jun 30, 2015 04:28 AM
UPLou
Jun 7, 2015 09:42 AM
CanadianViking
Feb 16, 2001 11:56 AM
