Snorkle tube collapse?
Old Aug 10, 2004 | 01:58 AM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
Default Snorkle tube collapse?
I think my snorkle tube may be collapsing while running the hill under a load, and then when I hit the nos I think it is promotes collapsing. I have about 5-6 heavy duty hose clamps to re-enforce, but it does not keep the tube from collapse.
Question is, has anyone tried to put some type of rubber cement between the hose clamp and the snorkle tube to hold the tube in place??? When the tube is under pressure it would seem to hold the snorkle in a round position if fixed to the clamps, instead of not being attached to the clamp... What kind of glue/rubber cement would you all recomend to adhere to the metal clamp and the rubber tube? Thanks
Old Aug 10, 2004 | 04:18 AM
Nobody has any ideas?, cat get your tounge?
Bigdaddy, you brought this to my attention and we have talked about re-enforcement, any ideas????????????????????????????????????????????? ??????????????????????????????????????
This may work?
Old Aug 10, 2004 | 05:43 AM
atvaddict01's Avatar
Why not try some small screws and then seal that with any type of adhesive
Old Aug 10, 2004 | 06:42 AM
Sandaholic's Avatar
What year is your snorkel tube? When I compared my 2002 tube with Blackhawk's 2003 tube, the 2003 tube was much more rigid and has additional ribs.
Old Aug 11, 2004 | 12:45 AM
SANDMAN430's Avatar
wouldn't rubber cement work? heck super glue might even work. good idea i might even try that.
Old Aug 11, 2004 | 12:46 AM
Thanks for the input atvaddict.
Sandaholic, I have the up-graded rigid snorkle..
I think some type of adhesive might work, but still dont know what to use till I go look around and hear more info.
Old Aug 11, 2004 | 01:08 AM
Rubber cement it is (thanks), I will try asap...
sandman- if you think your running rich, try this before leaning out gas jet on nos system just to be safe.
I think my snorkle tube was collapsing @ sand mt Ut. at the very top of the hill, I was losing power with the exact same symptoms.
Old Aug 11, 2004 | 01:14 AM
BomberX's Avatar
what exactly is the snorkel tube you guys are talkin about?
Old Aug 11, 2004 | 09:16 AM
sam's Avatar
sam
its the tube between the carb and the airbox, take a peek at my pics, I got one w/ my TM45 and it shows the snorkle clamped to the carb
I cant see why no one hasnt came up w/ a aftermarket snorkle. make a mold w/ the orginal and then use that to put a sutiable materal around it.
Idea?? what about wraping it in fiberglass? cant get no firmer than that like a cast or something[img]i/expressions/face-icon-small-smile.gif[/img]
Sam
Old Aug 11, 2004 | 03:04 PM
blue250r's Avatar
I have the 04 model which aparantly doesnt collapse as much
But if you can find it and fit it properly it might be woth trying a spring inside the tube i have done this for other aplications in the past,(not on the ds)
If u can get a good fit it will definatly not collapse , but it may cause some air velocity drop due to turbulance
