Twist throttle/Pro Taper questions
Old Aug 11, 2004 | 01:26 PM
Freakneh's Avatar
Default Twist throttle/Pro Taper questions
Does anyone know if a twist throttle for either a Banshee, or a 400EX would work on a DS? Of course I know the cables won't work, but is there a reason anyone can think of for the assembly to not function properly?
I've got one of each collecting dust, and I'd like to switch over.....
Also, I was just given a brand new Pro Taper handle Bar....without the fat bar adapter. Does anyone know where I could get one of these, and for about how much?
Thanks for the info,
Justin
Old Aug 11, 2004 | 05:38 PM
blue250r's Avatar
I see no reason the twist grip shouldnt fit the bar
If its your first time on a twist take it easy in the whoops until you get used to it , I love em and wouldnt use anything else. But plenty of people will give different acounts on them
Old Aug 11, 2004 | 06:32 PM
JMAC650's Avatar
I have Pro Tapers with a twist throttle and it work perfect. Just make sure when you get it installed you leave alittle play in the throttle so you won't be revving it on every little bump.
Old Aug 11, 2004 | 08:04 PM
Freakneh's Avatar
I love twist throttles, I've had them on everything but my last Banshee. I'll order up a cable. JMAC650, as far as the Pro Tapers are concerned, did you need a riser to use them, and where did you get your clamp at?
Old Aug 11, 2004 | 08:49 PM
JMAC650's Avatar
Check out my pics. I made a custom Roll Design stem.
Old Aug 11, 2004 | 10:15 PM
Freakneh's Avatar
That's right, I'd forgotten about that!!! That's a sweet set up!!! I want a clamp that will put my bars at the same height as the bars I have on now. I talked with a shop here in Tucson, and they only have a riser type clamp for 80.00.....That price makes these free bars, not too free anymore....
Anyways, thanks for the responses!!!
J
Old Aug 11, 2004 | 10:46 PM
lilnotts's Avatar
how much did that stem cost ya all together?
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
89Lt250r
Sep 7, 2015 07:53 PM
