95 Warrior oil/gas ratio??????
Old Aug 11, 2004 | 10:35 PM
ltandrew's Avatar
Default 95 Warrior oil/gas ratio??????
I thought you didn't have to mix oil with the gas on a four stroke. I'm looking at a manual that is telling me to mix it 20:1. This is my first four stroke. I love the sound of a two stroke but now have rode the warrior and felt the power it produces. It's awsome!!!!! Do I use 2-cycle oil in my four stroke???? How many ounces of oil should be mixed with a gallon to make 20:1?
Thanks
Old Aug 11, 2004 | 10:40 PM
orky4969's Avatar
No,
that shouldnt be accurate. I mix oil with a fourstroker ONCE IN AWHILE...... but not much my dirtbike...2-stroke moto-x takes a 32:1 ratio there-fore a 20:1 would mean more oil which isnt true.... i personaly wouldnt use oil, and would check my sources again, as warriors are 4-strokes and dont need oil, t hats the whole point of a 4-2stroke, one has WAY more RPM's, than the other which would call for oil, and i'll tell you, a warrior doesnt come close to the RPM's needed for oil.
my 2 cents.
Old Aug 11, 2004 | 10:46 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
it DOESN'T AND SHOULDN'T Take mixed gas.. should run on pump fuel straight pump fuel!
Old Aug 11, 2004 | 11:22 PM
Raptoryfn660r's Avatar
RIP Dear Friend
What ever you are looking at, its not a 1995 warrior owners manuel.
Old Aug 11, 2004 | 11:27 PM
ltandrew's Avatar
Thanks for the info. I'm about to take a night blast down the dirt road. With gas only. It was running 65mph with some oil in it!!! It has been backfireing when I let off. Is this normal?? It has the stock pipe but I think the previous owner removed something. There is a bolt hole at the end of it but nothing to hold in. It was in pieces when I bought it. I have installed a new piston 20 over.
Thanks again
Old Aug 11, 2004 | 11:28 PM
ltandrew's Avatar
Thanks Speedy
Old Aug 11, 2004 | 11:29 PM
trailcrawler's Avatar
2-stroke engines lubricate the crank bearings with the oil in the fuel when piston is on up stroke. 4-stroke engines have a sealed area in lower block for oil to be pumped or splashed on/in bearings as lube. oil in gas only will lube the valves and guides. sometimes gooey the plug if too much
Old Aug 11, 2004 | 11:35 PM
95wolv's Avatar
The bolt in the back bottom end of the muffler helps to hold in the baffle/spark arrestor, if the previous owner took it out, you'd know it, it would be pretty loud. I would get that oil/gas mix out of the tank pretty soon, you will just fould out the plug,no four stroke is made to run on a premix. The backfiring when you let off could be a lean idle mixture, under the carb,near the intake, you will see a screw coming out of the bottom,this is the idle mixture. Open it up a 1/4 turn at a time until the backfiring stops. If you can't get it to stop after going out more than 3 turns, you may need to clean the carb, or put in a larger size pilot jet.
ltandrew's Avatar
All right... So the manual I was reading only goes up to 1992. Lesson learned. I was looking at the YFM350X. What model would the 95 be for future specs???
Thanks Raptor
Old Aug 11, 2004 | 11:40 PM
ltandrew's Avatar
Me and that screw are pretty tight. I spent about a day with it trying to get it to start.
Thanks
