advanced timing and cooling, question
Old Aug 12, 2004 | 09:42 PM
minimus's Avatar
Default advanced timing and cooling, question
I plan on advancing my time from the stock 28 degrees to 37.
Dyna CDI=33+4 degree key.
Cooling: Water wetter + distilled water in radiator, during non freezing conditions.
Then go back to a glycol/water mix during winter.
Lubrication: That’s the main question does dura lube work when added to oil?
It claims to increase horse power and cool engine without Teflon (ptfe).
Does anyone have an opinion or knowledge why this is a bad idea?
I realize feds filled a lawsuit because of unsubstantiated claims like increasing engine life by 50,000 miles,
on both slick 50 and dura lube. But that does not matter to me if it works somewhat.
Thanks anyone.
Old Aug 12, 2004 | 10:42 PM
Customfabandweld's Avatar
You are going to replace the DG3 with the Dyna? Please post results! I may do the 4 degree key, if it works out for you.
Old Aug 12, 2004 | 10:53 PM
Marylandatv's Avatar
I heard some are already ruuning the CDI and 4*key with very good results! Its my next mod!~coop
www.MarylandATV.com
Prairie 700
Team Green Plastic
Progressive Springs
OMF Beadlocks
Maxxis Big Horns
Dyna CDI
EPI Pink Spring
Twin Air Filter
HMF Penland Exhaust
exhaust wrap
4* key
Vforce Cams
on the way!
Oh and a Bunch of other Toyz
Old Aug 13, 2004 | 01:10 AM
KISSSOFDEATH's Avatar
I have a 4 degree key and will be trying the Dyna CDI out this weekend.
SOLOLUCKY
Oct 4, 2024 09:09 PM
Bigredjeep
Jun 22, 2015 11:30 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
VascoConroy
Jun 12, 2015 10:30 AM
2punksdad
May 23, 2000 01:46 AM
