my lakota came without a string on the pull start....
Old Aug 13, 2004 | 01:44 AM
dadsworry's Avatar
Default my lakota came without a string on the pull start....
and im wodnering what I should do? should I take it to a shop and have it done and get chared out the a$$? or Is it easy enough To put a new one on? I havent dared too take the cover off of thing because I have no Idea what im doing. anyone ever put a new string on? whats involved in the process of it?.....
Old Aug 13, 2004 | 07:21 PM
kwackermann's Avatar
.... Well-- the sad truth is that if you really don't have any familiarity with such things, unfortunate as that is- then you'll just have to take it in the old pooper....
Old Aug 13, 2004 | 10:05 PM
bmj67's Avatar
i have never put a pull rope on a lakota, but if its the same as on a quadrunner it will be easy to do. you just need to get some good nylon rope.
take off the pull start cover there should be a spool thing.
take that off but be careful bacause there is a spring under it which makes it recoil back in, and if it comes loose its a pain in the *** to put back in.
then just put the new rope on use a figure 8 knot. then you just put the spool back on and wind it up then fish the rope through the hole in the cover.
i normally pull it all out and put visegrips on the rope near the hole that way i can tie the end to the handle easier. use a figure 8 knot again on the handle and your done
Valder
Nov 28, 2020 07:38 AM
fordfaithful21
Dec 7, 2015 05:52 PM
SDR-II
Sep 29, 2015 01:06 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
black798
Sep 9, 2015 07:42 AM
