SPEED-O GONE HAY WIRE
Old Aug 15, 2004 | 08:35 PM
deerchooper's Avatar
Default SPEED-O GONE HAY WIRE
Have anyone noticed there speed-o being a little slow or retarded? The other day i was riding and looked down and it said something like 32 mph. then i hit the gas to make a top end run, looked down after i started to go and it read like 25 mph. i thought it was a fluke. yesterday i tryed it again and the same thing happened. it went from 35mph, down to 13mph and then it caught up to 44mph.
how am i to do test and tune if the speed-o aint working?
i was just wondering if anyone else had this problem.
i just hope its the sending unit, because i know the dash would cost some change.
____________________
02 650p
see pictures for mods
Old Aug 15, 2004 | 11:49 PM
Kawi650's Avatar
I'm guessing it's the wire from your speed sensor. With the timing changes with speed sensor. Also your 4wd etc. also is speed sensor related. Also if you have a holeshot mod would by pass the effect on your CDI.
Old Aug 16, 2004 | 12:05 PM
MikeyBoyesq's Avatar
Is your quad wet when the speedo went haywire??? My speedo used to act funny when I washed it...I figured out that the speed sensor wire or DG holeshot wire was getting wet (I had an on/off switch for the holeshot module mounted on my handlebars plastic at that time)...as soon as it dried off, the speedo-worked good again. Now I no longer have that problem b/c I removed the DG holeshot (and installed the Dyna CDI in its place).
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 16, 2004 | 05:08 PM
NO WATER, NO HOLESHOT
___________________
02 650P
toonces
Sep 5, 2015 01:14 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
quickwhips
Sep 2, 2015 06:53 AM
frostphase
Aug 19, 2015 07:11 PM
DeFox500
Jul 26, 2015 06:32 PM
