400EX oil
Old Aug 16, 2004 | 07:38 PM
SickRider's Avatar
Default 400EX oil
What's the best oil I can get for my 04' 400EX? I mostly ride trails and sand a few times a year. take good care of it and I always change my oil before every 20 hrs. I don't have any mods done to it but maybe a few in the future. I don't know if this stuff matters too much but any repplies would be appreciated.[img]i/expressions/face-icon-small-smile.gif[/img]
Thanks,sickrider
Old Aug 16, 2004 | 07:51 PM
Ozark38's Avatar
Default 400EX oil
I use to use Hondas GN4 but I didn't much care for it. I just switched to Mobil 1 MX4T and so far so good. At 8$ a quart I won't be changing it as much........[img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 16, 2004 | 09:41 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default 400EX oil
http://forums.atvconnection.com/mess...did/415309.cfm
I use Honda HP4!
Old Aug 17, 2004 | 09:09 AM
bullhoggrande's Avatar
Default 400EX oil
I am changing the oil on my quad tomorrow myself for the first time. Can anyone tell me how you measure out 1.96 quarts of oil? I am slow not stupid.
Old Aug 17, 2004 | 10:09 AM
Red Rider
Default 400EX oil
Depending on the brand of oil, there is usually a clear strip on the side of the bottle, with numbers on it that can be used to tell how much oil you have poured. You will need a long neck spout of some kind.
When you drain both your sump and crankcase (the bolt on the side of the engine), the sump will not hold the full amount of oil (it will overflow!) when you first fill it. I put in about 1.8 qtz., then I start the engine for a minute to let the oil pump fill the cranckase, oil cooler, and filter. Stop the engine, then add the rest of the oil. With an oil filter change and cranckase, it takes more like 2.1 qtz.
Check your oil often, and check it on a warm engine that has sat for a few minutes.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
