prairie 360 question
Old Aug 16, 2004 | 10:59 PM
alwaysride's Avatar
Default prairie 360 question
ok, when im driving in 4 wheel drive somtimes i hear a sould from the front end like it is metal moving around. Im almost sure its no big deal but i am a neat freak on this kinda stuff. somtimes i turn the handlbars when it is not even on and there is like a little pop and then its fine.when i was taking a closer look, when the 4 wheelers was off i grabbed the front cv and tryed to rotate it in the forward and back and it moved just slightly and a then pushed it in twards the shaft and it had just a slight amount of play in it also, is this supposed to be here or not. Try in on your to see if yours dose it
Old Aug 22, 2004 | 10:54 PM
OleManMoses's Avatar
Hey alwaysrides
When I am in 4 wheel drive, especially in low range going down vertical hills that I wont go back up, my frontend clanks and clunks especially bad at slow speeds. It does not make any noise when hammering it through the mud in wheel though---I would guess that yours is normal---You might want to try changing your front end oil--I keep saying I am going to put the mobil 1 5w40 in it that I run in the crank, but I havent gotten around to it yet.
From bits and pieces Ive picked up from this site, I would have to sat Kawi's are reliable, BUT NOISY!!
What year is your 360?
Old Aug 22, 2004 | 11:20 PM
alwaysride's Avatar
hay, my 360 is a 2004. i also want to ask about the 4wd indicator. Some times when i go ride the light flashes but nothing i can feel machanically is wrong or doesnt work. i think it flashes at 1 sec but cant tell but its done it a couple of times and all i do is turn it off and it stops. what is wrong do you think. thanks
Old Aug 23, 2004 | 11:21 AM
how many hours on your machine??? Do you have a speedometer?? do you have the owners manual?? Maybe your 100 hour light needs reset
Old Aug 23, 2004 | 12:35 PM
alwaysride's Avatar
I know i dont have a hundred hours yet but i want to know what is with the flashing. should i be woried about the 4wd light flashing
Old Aug 23, 2004 | 02:49 PM
If I'm not mistaken, I think the owners manual gives a description of what the flashes mean---if not, search the site, it has been discussed many times
hueby
Nov 6, 2015 11:34 AM
bigred20653
Oct 2, 2015 10:05 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
bigred20653
Sep 19, 2015 02:11 PM
PrairieDog126
Sep 12, 2015 05:23 PM
