Grizzly Help Perfomance Mods
Old Aug 17, 2004 | 10:49 AM
freemans30th's Avatar
Default Grizzly Help Perfomance Mods
I have a dr.d slip on. Pro flow setup with K&N and rejetted the carb now it runs sluggish what should i do to fix it what jet should i use in the carb.
Old Aug 17, 2004 | 10:03 PM
batmanacw's Avatar
Does it pull okay into the mid range and stumble on full throttle? If it does then it may be rich on the main. I jetted mine richer until I got a full throttle stumble and then when back one jet. Mine was flat on the top end because it was lean. I am running a 175 dynojet. I was a little sluggish after installing my pipe, but it was because I was restricted on the intake. When I installed 12 uni filter vents in my lid it helped, but I was running the required 155dj. I am now running a 175 dj and may end up at a 180.
Old Aug 19, 2004 | 03:19 PM
All is awesome now it pulls hard all the way through the guy that jetted my carb did not put the spring back in. I have a dalton clutch kit what would this do to my performacne if i install it. I do not want it poppin up on me going up hills what would this do I have the 26 itp tires also.
Old Aug 19, 2004 | 06:05 PM
batmanacw's Avatar
The clutch kit will probably raise the engagement rpm a little. I have an EPI and I really like it. It engages very smoothly, but at a higher rpm so it has more low end grunt. My griz will lift the front end off the ground without any effort in high gear. All I do is sit on the back of the seat. It will only do it from a dead stop. I haven't gotten it to do it on a roll. It is up to you to control how much gas, so I don't think that it will be a problem to have that much horse power on a steep up hill.
Old Aug 19, 2004 | 06:10 PM
where did you get your epi clutch kit from and did you put it in yourself or have someone do it for you. If you put it in was it hard to do. Thanks for all the help.
Old Aug 19, 2004 | 06:20 PM
batmanacw's Avatar
I ordered it from EPI direct. I wimped out and had someone else do it because there are some powerful springs in their and I didn't want to mess with it.
Old Aug 20, 2004 | 11:00 AM
When you put your pipe on did you take off the factory heat shield stuff on your factory pipe and put it around your new one.
Old Aug 20, 2004 | 02:59 PM
batmanacw's Avatar
No I left it off. My storage box got a little hot so I put metal tape on it to reflect the heat. I haven't had any problems since. I also used a stack of washers to put between the pipe attachment point and the frame to make a little more space. It looks pretty good.
Customer Service #1
May 15, 2020 08:46 AM
cboler9
Sep 24, 2015 08:35 PM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
