drilled 7 1" holes in 400ex airbox lid/ rejet?
Old Aug 19, 2000 | 02:51 AM
allnamesaretaken's Avatar
took my airbox lid all the way off and man did it run! but didn't want too much debris getting in there so drilled seven 1" holes, should I rejet since it'll be leaner? also just installed curtis sparks ignition advance keyway, will post the results.
Old Aug 19, 2000 | 12:16 PM
2000EX's Avatar
I too have gone the 6 hole route for airbox modification. Use the filter vents made by Uni, I have had no problems thus far. They are cheap and very easy to maintain. You dont want to run the risk of running lean, so I would say go up 2 sizes on the main to a 155 then test from there. Good luck!
Old Aug 19, 2000 | 01:23 PM
snowshark's Avatar
Get the air vent filters & yes rejet if needed. You most likely will need one possible two sized bigger than your stock.
Old Aug 19, 2000 | 10:54 PM
IndyDave's Avatar
I took the airbox cover off my scrambler, and it ran AWFUL. Started and idled fine, but wouldn't take the throttle at all. Makes me think that it'd really run re-jetted. Don't really want to leave my airbox open all the time. I ride in alot of sand.
How much trouble is it to change a jet. Would it be worth changing it for different conditions ?
Thanks,
Dave
Old Aug 20, 2000 | 12:30 AM
DAD400EX's Avatar
I drilled 10- 1" holes in my lid,using white brothers filters,jet size 152,and runs awesome.
I bought another lid from Honda($5),in case I want to run in mud,rain or what ever.
2000-400ex
fmf powercore4 exhaust
white bros. rev limiter
K & N air filter w/pre filter
use Klotz everthing for oil,lubs,& etc.
Rethel handlebars (400ex bend)
Holeshot tires,ITP rims
Sassinm1
Sep 30, 2015 04:23 AM
2many2ride
Sep 27, 2015 04:35 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
