trx300 transmission whine
Old Aug 21, 2004 | 10:20 PM
jmattbailey's Avatar
Default trx300 transmission whine
When I start up and my bike starts to idle for a few seconds, the transmission starts to whine fairly loud, but if i ease up maybe 1/8th of an inch on the shifter this stops. The sound doesnt seem to be hurting anyone, just wandering what it may be and if it will hurt it in the long run?
Old Aug 24, 2004 | 08:02 PM
camp's Avatar
my 94 trx 300 did the same thing and it was the clutches at first i ignored it butt then it got worse so i took it to the dealer to have them fix it when they took it apart all the clutches and friction plates were worn out and with the clutch not engaing all the way the teeth on the gears were starting to get worn so every time i would try to get spee the gears would spin it costed over a $1000 dollers to fix it so STOP driving it be 4 u have to replace the whole tranny.
Old Aug 25, 2004 | 02:52 PM
do you reccomend repacing the clutch plates springs?
Old Aug 25, 2004 | 04:35 PM
camp's Avatar
yes
Old Aug 25, 2004 | 09:46 PM
TrailBlazerguy250's Avatar
not a good thing to happen but thos ol' 300 are beasts, I use to own one, kick my slef everyday for sellin it lol
Old Aug 27, 2004 | 01:07 AM
I talked to a good honda mechanic today and before i could finish my sentence, he chimed in and told me all about my problem, even told me what the noise sounded like. Says he's worked on 300's before, replaced clutch one way bearing, the works and still the whine existed. This has definately given me some peace of mind, but i will keep watch on the noise.---your right trailblazer, i just traded my 300ex for the fourtrax 300 and i love it! no more chain,bearing,reverse procedure worry. a true beast!
Old Aug 27, 2004 | 01:28 AM
Raptoryfn660r's Avatar
RIP Dear Friend
When its idling just it go like hmmm, uhhh,uhhh, uhhh, hmmm, uhhh, uhhhh, Hmmm near the center of the trans case under the carb?
Old Aug 27, 2004 | 01:42 AM
Well i dont know about the hmm...uuuu....but it does sound like the internal components, are spinning, while in neutral. But when i put it in gear this stops, another reason i was convinced by the mechanic cause he told me this would happen. I would say the sound is coming more from the side of the engine in front of the shaft.
Old Aug 27, 2004 | 01:45 AM
...also the noise doesnt start right when i turn the bike on, just a few seconds later and it sounds like it winds up gradually then stays at a certain speed
Old Aug 27, 2004 | 01:53 AM
RIP Dear Friend
I wouldn't worry about it.
Even if I had to spend some money on mine it still has a place to call home.
Sorry about the sound effects but its the internet.
