strut housing seal/ hub problem
Old Aug 22, 2004 | 08:19 PM
BigBadScrambler's Avatar
Default strut housing seal/ hub problem
Anyone ever replace a strut housing seal? Mine is leaking and I am just wondering what I am in for. Any tips? Also, my hub wont kick in on the same side. I havent had a change to tear into it yet, but any ideas? It had fluid in it too. I am thinking that I should check for power to the hub first. Then I will take the hub apart and turn the 4wd on and see if the armature plate sticks to the magnet. Speaking of the armature plate, it looks a little worn. Could that be a cause? And ideas or diagnosis procedures would be greatly appreciated.
Old Aug 24, 2004 | 01:46 PM
camoman's Avatar
It's not a big deal at all.. The fact that your 4wd isn't kicking in is porbably due to the lack of fluid in your hub as a result of your leak. You will need to take your hub off , undo your tie rod end and ball joint. Remove your axle from the housing and use a seal puller to rip the old one out. Be very careful driving the new one in as it is a little awkward.. use a seal driver.
Old Aug 24, 2004 | 02:09 PM
actually it is a slow leak. I replaced the hub seal hoping that was the problem. When I put it back together and refilled the fluid, thats when I tested the 4wd and it wouldnt kick on. It takes a few days before you start seeing the leak. So it has to be something besides the fluid. I think I will take the strut housing off and let the dealer replace the seal. That way if something goes wrong, they are replacing it not me. But I wonder if the magnet is bad?
Old Aug 24, 2004 | 03:16 PM
camoman's Avatar
You can try check the wries to make sure they are not pinched.. I know mine was and I couldn't see the brake but it was there.. I can't see that happening on both sides though.
Old Aug 24, 2004 | 03:28 PM
It is just on the left side that it is not working
Old Aug 24, 2004 | 03:34 PM
camoman's Avatar
Do you have a clamp that supports the wires and the break hose and attaches to one of the strut bolts? If you do make sure that the wire is not pinched there ..
Old Aug 24, 2004 | 03:48 PM
I will have to check that. Thanks
skinnyr6
Aug 25, 2023 02:18 AM
Firefighter400
Oct 8, 2022 06:38 PM
SDR-II
Sep 29, 2015 01:06 AM
Captjay
Jul 23, 2015 12:33 PM
steveo612
Jul 11, 2015 08:35 AM
