help prairie owners please?
Old Aug 24, 2004 | 02:28 AM
droil5's Avatar
Default help prairie owners please?
i have an 04 ac 650 and i have yet to be happy with the clutch and belt adj
i have epi red sec spring pink primary epi weights and dayco hp 2017 belt and it is now slipping too changed
kawi belt at 500k and now have 1000k on dayco i want to change it now but i want it done right this time
what have you guys found works best ?
Old Aug 24, 2004 | 10:17 AM
newbeatle's Avatar
DROIL... have you been having a problem tripping the belt trip switch, like a lot of other Cat 650 owners have expirienced ???
what do you currently have in for shims in the secondary ???
I have not run the Dayco belts yet, & don't know the Item numbers off the top of my head... is the 2017, the 650 belt, or the 700 belt ???
I have heard several complaints of the belt life, on the Dayco belts ( weather they are founded or not, I don't know )... I understand them to be a softer rubber compound, & somewhat narropwer, & possibly a little longer than the O.E. belts...
I would personally run the O.E. Kawasaki belt, & install the 700 or 360 belt, & shim it on the tight side ( it may get there, just by switching to one of these belts, if you are currently running a 650 or equal belt, as they are wider... this will likely allow you to just replace the belt, with out opening your secondary again...
Old Aug 24, 2004 | 12:48 PM
droil5's Avatar
newbeatle the 2017 is the 700 belt according to dayco website
i have not yet worked on the bike myself at this point i have the cover off
but dont have any of the special tools for dissasembly where are the shims at
i am looking for? now that i see i have a red spring in the sec what do you think
what do you think ishould have for shims o ya been lucky limp mode 5 times in 1000k
Old Aug 24, 2004 | 01:08 PM
newbeatle's Avatar
DROIL... the 700 or equivilent belt, should be an upgrade from the 650 belts, it has a better shieve grabbing shape, & is wider & stronger ( in O.E. configuration )... I will add an addy for NYROCS tech tips, which will show you how to make the needed tools, & offers the best collection of data on belt adjustment, that I know of... most likely, if your service has been done at a Cat dealer, they are unfamiliar with setting the Kawi clutch up...& have been giving you too loose a setting to start with... if you don't get the mileage out of the next Dayco belt, once the deflection has been set to the tight side of the specs, than you may find better service with the O.E. belt, given the additional weight of the Cat, over the Prairie... once you get you hands dirty on the Kawi style clutch, & have a reference source, Like NYROC's site, you'll find working on the CVT, relitively easy...
IMO, most of the Cat related belt trip switch problems ( problems with actually tripping the switch inside the belt cover ), is either related to too loose a belt, to start with, or could be related to some sort of flexing ???
sorry, you'll have to cut & paste this to your browser, as I've not been able to do links on this forum... look here...
http://atv.dnsalias.com/tipview.cgi?dir=Prairie
Old Aug 24, 2004 | 01:24 PM
Metallikev's Avatar
NB..to cut and paste just use the clipboard icon on your reply window...that will copy from your clipboard or it will copy to your clipboard..
Old Aug 24, 2004 | 01:31 PM
newbeatle's Avatar
Text
see if this works... I'm not ignorant, just lightly handicapped...
Old Aug 24, 2004 | 01:34 PM
newbeatle's Avatar
Thanks METAL... I guess you can teach an "old dog" new tricks... I had tried to do this, when I 1st became active on this forum, & was unable to get it to work... I don't know wat I'm doing differently now ??? as long as I remember how to do it next time...LOL
NYROC's Tips
Old Aug 24, 2004 | 01:45 PM
Metallikev's Avatar
NP,always glad to help an old dog in need a of a new trick..lol.. [img]i/expressions/face-icon-small-happy.gif[/img]
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
Ahtatu
Sep 28, 2015 12:14 PM
