Racing gasoline for mojave
Old Aug 20, 2000 | 05:01 PM
MajaveFreak's Avatar
well i just put new white bros. cams and a wiseco high compression piston in my mojave. i read somewhere you might have to use a higher octane gasoline if you get new cams and a new piston. i was just wondering if there`s anyone who uses racing gasoline or an octane booster on their mojave after they put new cams and new piston in it.
Old Aug 20, 2000 | 11:25 PM
KawasakiKid's Avatar
That depends on the degree of compression you're using.
Octane boosters do not technically raise octane numbers, despite popular opinion. They stabilize the fuel so that it can burn properly in high compression engines.
Running too low of octane in a high compression engine will result in the gasoline pre-detonating or knock, as some call it. This can burn or blow a hole in your piston relatively quick if prolonged.
Below you’ll find a snippet of some technical documentation I’ve drummed up and my references (just in case someone wants to debate me)
Compression Octane Number Brake Thermal Efficiency
Ratio Requirement ( Full Throttle )
5:1 72 -
6:1 81 25 %
7:1 87 28 %
8:1 92 30 %
9:1 96 32 %
10:1 100 33 %
11:1 104 34 %
12:1 108 35 %
Reference 1.
- Chapter 20. K.Owen.
Automotive Gasolines - Recommended Practice.
SAE J312 Jan93.
SAE Handbook, volume 1. ISBN 1-56091-461-0 (1994).
You can get away with running lower octane than listed above, but the values listed are basically the most efficient to use.
Also, keep in mind timing plays a huge role in regards to comp ratios and octane. The higher your timing the more octane you’ll want.
I hope this helps.
Old Aug 23, 2000 | 11:41 PM
JD250R's Avatar
I have a Wiseco 11.5:1 piston, cams, porting, and a lot more and I have no trouble using 92 pump gas.
Robinhood
Dec 26, 2015 10:28 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Sep 1, 2015 01:45 AM
