plowing with sportsman500ho
Old Aug 24, 2004 | 08:28 PM
lancesamuel's Avatar
Default plowing with sportsman500ho
I am getting a plow for my 2001 sportsman 500 and just checking to see if ok to use same struts up front or are you guys using anything different for struts... Any issues etc.. Thanks for any info
Old Aug 24, 2004 | 09:22 PM
Polaris500HO4x4's Avatar
its ok
give - r - hell
Old Aug 24, 2004 | 10:48 PM
yammaslamma's Avatar
you can do it just fine, just make sure if your gonna go on a longer trip between trips or something use straps to be easy on the winch and also on long stops put the blade down to take some pressure off the front.
Old Aug 24, 2004 | 11:11 PM
xcrider's Avatar
Pick up the rubber spring spacers I think they go for under $20 a pair. Easy to install and will help a ton.
shimanok2
Jan 29, 2016 07:37 PM
kampswas
Sep 23, 2015 05:05 AM
stcspiderman
Sep 13, 2015 05:15 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
