250X smoking
Old Aug 20, 2000 | 09:41 PM
BigDogX's Avatar
I just replaced the rings and top end gasket in my 250X, and it is running great, but one thing is wrong and that is in the carburation... its smoking mostly just black smoke, im sure its running rich and either i need to move the needle clip up a notch or get a smaller jet and see what that does... what do you guys think??
Old Aug 20, 2000 | 10:14 PM
letitsnow's Avatar
What position is the throttle in when it smokes? less than 1/4, 1/4-3/4, WFO?
Old Aug 20, 2000 | 10:37 PM
BigDogX's Avatar
Pretty much all the time... not when idling, but about 1/4 to WO it smokes... i hope its just running rich... any ideas what to do?
Old Aug 20, 2000 | 10:54 PM
BigDogX's Avatar
I just thought of something, if i removed the air box lid do you think this would cause enough air flow to make up for the richness in the fuel mixture... what do you guys think???
Old Aug 21, 2000 | 06:39 AM
puddding's Avatar
should only leave the clip on the needle where it was std
bike that age (like mine), may burn oil on start up as well.....something to watch
all it is, is worn seals around the valve stems allowing oil to seep down onto the piston when you stop the engine....on start up it burns it off....now worries though
replacing the topend gasket and rings should not require a change in the carby setup
r u running a std air filter?
exhast
mainjet?
airbox lid
anyway ride hard
and search the forums
this topic is well discussed
pudding
Old Aug 21, 2000 | 09:25 AM
BigDogX's Avatar
Its a big long story on how the carb is messed up and i dont want to go into it... but it has always been running rich, even with the clip in the leanest position.... so i think i might try the smaller Jet... thanks
Old Aug 21, 2000 | 02:08 PM
briancwatkins's Avatar
Pudding,
Correct me if wrong, but if it were oil burning, wouldn't the smoke be white?
Old Aug 21, 2000 | 02:24 PM
BigDogX's Avatar
itd be white or blue, this is black, so its running rich most likely...
Old Aug 22, 2000 | 03:24 AM
JRM's Avatar
JRM
Pull off the carb, flip it upside down and bend the float so it is level when upside down. This should cure the problem. To high float level will make it run super rich no matter what jets you try as the fuel litterly gravity feeds itself in.
Old Aug 22, 2000 | 06:09 AM
puddding's Avatar
yup true.....
what year
what main jet
what JRM said sounz like a plan
