Secondary clutch bushing fix.
Old Aug 25, 2004 | 09:47 PM
SHOTGUN's Avatar
Default Secondary clutch bushing fix.
I have read where people had to replace the bushing or bearing in the secondary clutches in the 02.
Anyone have any information on a fix or know who has done it.
Thanks in advance.
Old Aug 25, 2004 | 10:27 PM
Dangerous's Avatar
Been there done that! Only problem is it has been a while so I can't give you the bushing numbers. Any reasonable machine shop should be able to fix you up by replacing the original bushings with some good oilite bushings and fitting them for $50 or less. The bushings cost me less than $8.
Old Aug 25, 2004 | 11:14 PM
KISSSOFDEATH's Avatar
Your messing up shotgun?
Old Aug 26, 2004 | 08:12 AM
SHOTGUN's Avatar
Yes, I let someone borrow mine, they took it apart to try a different spring and reported that mine was bad. another guy also wanted to borrow mine because his bushing was gone.
I know on Nyroc site there is a guy that had a fix. just wondering if anyone on here has done it lately. where they got the parts and who did it.
Old Aug 26, 2004 | 12:30 PM
Cuda440's Avatar
i also have a old secondary clutch I'd like to repair. Doe's anybody have the O.D. and I.D dimensions?
Old Aug 26, 2004 | 01:40 PM
NovaKaw650's Avatar
A guy named ConcoursQuebecCanada on the forum had the dimensions posted at one time. I did a search but couldn't find it, though.
Old Aug 26, 2004 | 01:45 PM
SHOTGUN's Avatar
He posted 44mm od x 40 mm ID x 20mm deep. Its on Nyroc site under 650, then Driven clutch fix.
Don't know if it's right but I will in a few days.
Old Aug 26, 2004 | 02:25 PM
newbeatle's Avatar
Here is the original thread...
original thread
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
jbrewster94
Sep 23, 2015 04:16 PM
cdstang
Aug 31, 2015 07:52 AM
