Raptor Tires
Anyone put taller front and rear tires on their Raptor. Did it affect the handling much? Make it feel more tippy? What about gearing, did that change much? I was looking at buying some holeshot xct's for more rear ground clearance.
i put some 22 on the back of my raptor gave it a little more clearnce and also increases top speed but if you did go bigger in the rear i would drop 1 tooth on the front sprocket to make up for it check out this site to help you with tire and gear ratios
gear calculator
gear calculator
Aug 21, 2015 01:23 PM
