Transmission Fluid SP500 HO
Old Aug 29, 2004 | 12:03 PM
Moneydog's Avatar
Default Transmission Fluid SP500 HO
Does anyone know what type of equivalent tranny fluid to use instead of the Polaris stuff? I have a 2003 500 HO and I have been told everything from 0-40 engine oil to 80-90 synthetic gear lube. Beacause the rear crankase is part of the tranny system (as far as lube goes) does it make sense to use the 80-90 or is there a tanny fluid out there that is fit for purpose for my machine???
Old Aug 29, 2004 | 07:17 PM
95sport400's Avatar
Unless they changed the tranny on the newer ones, neither one is what you want. It uses chaincase lube just like a snowmobile. Amsoil Series 2000 chaincase lube is the way to go.
Old Sep 18, 2004 | 04:00 AM
PhilFixit's Avatar
The Polaris AGL is just a synthetic Dexron III ATF.
It takes 948 milliliters (32 ounces) from dead empty.
You'll probobly only get about 26 ounces into it, as it's tough to get the snorkel empty.
If the drain plug has an aluminium washer, torque it to 16 foot pounds ot it'll leak.
If it's plastic, use a little thread sealant and 12 pounds of torque.
>You really can't go wrong if you stick to the Polaris lubricants - really.<
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
