What do you clean the air filter element with???
Old Aug 30, 2004 | 10:56 AM
RoadLizard's Avatar
Default What do you clean the air filter element with???
The manual says to use a low flash point cleaner for the air filter element.
What the heck is that??? Suggestions??? confused;
Thanks all,
Mike:
Old Aug 30, 2004 | 11:10 AM
mudmonkey72's Avatar
I just went out and got the K&N filter cleaner and oil for my foam filter. It seems to work good.
Old Aug 30, 2004 | 11:31 AM
Metallikev's Avatar
a good carefull soaking in kerosene ..dont stretch or damage the material..after the kero disolves the filter oil squeze it dry as best as possible without ringing it dry(that will damage the element) let dry for a few hours then take hot soapy water and repeat the cleaning process with that..squeze dry again (no wringing)..let dry well,then spray with your choice of filter oil( i use PJ1)..let that coat dry and look for missed spots //dont over coat but dont be stingy either..it takes about a day to dry completely before the oiling so its best to have a spare filter on hand..thats why i have a twinair and kept my stocker..just in case i need to swap quik..and another tip is to get a can of white lithium spray grease and lightly coat the inside of the airbox lid..this will take some of the load off the airfilter itself and can be easily wiped out with a cloth and resprayed on..you wouldnt believe how much dirt that grease catches before it contacts the airfilter itself...good luck..
Old Aug 30, 2004 | 11:32 AM
Metallikev's Avatar
Originally posted by: RoadLizard
The manual says to use a low flash point cleaner Suggestions??? confused;Thanks all,Mike:
lol,a good low flash point solvent is kerosene...lol
Old Aug 30, 2004 | 01:09 PM
Marylandatv's Avatar
Just swing by your local Hardware or Walmart store and pick up some mineral spirits,
Its a very mild solvent and I think the best, cleanest and cheapest to use. Twin Air
also makes a tub cleaning setup that is good and has IMO the best foam filter. The
directions on most all of the filter oils with help teach you how to maintain your filter.
~coop
www.MarylandATV.com
Prairie 700
Team Green Plastic
Progressive Springs
OMF Beadlocks
Maxxis Big Horns
Dyna CDI
EPI Pink Spring
Twin Air Filter
HMF Penland Exhaust
exhaust wrap
Vcams
4* key
on the way!
Oh and a Bunch of other Toyz
Old Aug 30, 2004 | 02:02 PM
RoadLizard's Avatar
Thanks gang.... appreciate the quick responses! [img]i/expressions/face-icon-small-smile.gif[/img]
Mike
Old Aug 30, 2004 | 06:18 PM
Metallikev's Avatar
Originally posted by: Marylandatv
Just swing by your local Hardware or Walmart store and pick up some mineral spirits, Its a very mild solvent and I think the best, cleanest and cheapest to use. Twin Airalso makes a tub cleaning setup that is good and has IMO the best foam filter. Thedirections on most all of the filter oils with help teach you how to maintain your filter.~coopwww.MarylandATV.comPrairie 700 Team Green PlasticProgressive SpringsOMF Beadlocks Maxxis Big HornsDyna CDIEPI Pink SpringTwin Air FilterHMF Penland Exhaustexhaust wrap>Vcams4* key on the way!Oh and a Bunch of other Toyz
thats mineral spirits..not mineral oil..big difference...
Old Aug 30, 2004 | 06:32 PM
BigSix's Avatar
jack daniels gives me a pretty low flash point...thats why i got arrested once
Old Aug 30, 2004 | 06:34 PM
BigSix's Avatar
oh **** i think i just reported myself to a moderator....well at least i know how that whole deal goes now.
Old Aug 30, 2004 | 06:36 PM
Mineral Oil works great to flush and clean out your system! Thats your system, not the quads!~LOL
www.MarylandATV.com
Prairie 700
Team Green Plastic
Progressive Springs
OMF Beadlocks
Maxxis Big Horns
Dyna CDI
EPI Pink Spring
Twin Air Filter
HMF Penland Exhaust
exhaust wrap
Vcams
4* key
on the way!
