Raptor's grounded
Old Aug 30, 2004 | 11:04 PM
AARaptor660's Avatar
Default Raptor's grounded
Okay so I bought this speedo(don't ask me why) and I was going to put it on tonight with my dad. Anyways, we take the wheel off and start to take off the rotor but we got stuck there. You see we can't get the rotor off because of the brake thingy(i'm really bad at mechanics). And we can't get the brake thingy off because of the rotor. Is there anyone who knows what i'm talking about and can help or give me a differant solution. Thanks[img]i/expressions/face-icon-small-confused.gif[/img]
Old Aug 30, 2004 | 11:07 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
u try taken m both off at same time ??
Old Aug 30, 2004 | 11:09 PM
yamrpt660r's Avatar
front or rear? im guessing front... the brake shield filled with holes? two bolts hold it on look around it form what i remember
btw if its not that digital speedo where did you find it?
Old Aug 30, 2004 | 11:11 PM
Speedy2222's Avatar
i hate to answer for him but it's prolly a trail tech speedo...
Old Aug 30, 2004 | 11:30 PM
No, front, confused and your right. we got it so the thing that holds the pads is loose, but there is this little peg that keeps it from pulling off the side of the rotor, make any sense?
Old Aug 30, 2004 | 11:40 PM
yamrpt660r's Avatar
thats the brake calplier are you a blonde or something?
youll figure it out
Old Aug 31, 2004 | 03:01 AM
1LeSSRaptor's Avatar
It's easy, just like a front wheel drive car. You take the 4 lugs loose, pull the wheel. You have two bolts on the inside of the caliper. Take those off and your caliper slides off the rotor. Let it hang, and if you need any more taken apart (Shouldn't), then pull the pin and the large nut loose on the middle of the 4 lugs and the rotor will slide off the spindle. Easy enuff?
Old Aug 31, 2004 | 08:56 PM
It's on the front wheel you know. Someone look up there and to the inside of the calipier and tell how to get that pin off, no wrench will fit.
Old Aug 31, 2004 | 09:16 PM
pinheadedjoker's Avatar
um do u have ur repair manual?
Old Aug 31, 2004 | 09:20 PM
its not hard i just checked it out to verify.. there are 2 bolts unod them the caliper comes out.... not hard/
