Mojave jetting on the spot, except for cold starts.
Old Aug 31, 2004 | 12:25 AM
96lapiscoupe's Avatar
Default Mojave jetting on the spot, except for cold starts.
I'm having a hard time starting my Mojave since I messed with the jetting after a clamp on filter last week. It literally takes 10-12 kicks to start when its dead cold. After it warms up its starts immediately, from reading it looks like the idle air mixture screw would have the most effect on this???? Should I try leaning it out or going richer, I'm 2 turns out on the screw now per the dynojet jetting instructions for my mods. Any suggestions, my leg is getting sore lol.
Old Aug 31, 2004 | 03:00 AM
BigSix's Avatar
i would richen the screw...go amybe 1/4 to 1/2 turn at a time until you notice it getting better..i say richen because when you use the choke to start something it is essentially richen the mixture by reducing the amount of air available at that time if i am correct...not 100% tho...
Old Aug 31, 2004 | 10:30 AM
SANDMAN430's Avatar
you might want to look at a size bigger pilot jet.
Old Aug 31, 2004 | 11:37 AM
OleManMoses's Avatar
from what i understand---never set the idle air or fuel screws by number of turns, adjust screws while idling to best idle speed
Old Sep 2, 2004 | 06:01 PM
mojaveaddict's Avatar
Bingo
let warm up. adjust mixture screw to best idle. should take 3 turns or less if the pilot is the right size. then you may want to turn the screw a 1/4 turn richer for easier cold starts. However your choke should take care of cold starts.
It enrichens the mixture to help cold starting. Are you using the choke? Is there any difference between using the choke or not when cold starting?
Old Nov 21, 2010 | 12:56 PM
xcapone861's Avatar
hey man i just bought a 250 mojave and i feel like something is holding it back. is there a speed limiter on it or something?
ultangler
Nov 30, 2024 01:35 AM
95wolv
Sep 27, 2024 12:00 PM
EIF
Apr 20, 2017 07:15 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
