Carburetor Trouble
Old Aug 31, 2004 | 01:14 AM
Valhalla007's Avatar
Default Carburetor Trouble
I have just purchased a 2000 Trail Blazer 250, and it has what I think is a jetting issue. It will idle normally, but if I open the throttle at all, it will bog and die. I pulled the airbox cover, and it looks like fuel is blowing back into the airbox. I have never seen this happen before, and I was hoping someone here would know the cause.
Bruce
Old Aug 31, 2004 | 01:26 AM
B200's Avatar
it sounds like u just need to adjust the carb
Old Aug 31, 2004 | 12:33 PM
Thanks, I suspected that, but don't know where to start. I just pulled the carb apart, and the only thing I noticed was the main jet is a 160, and the stock size should be a 130. I thought that would make it too rich at the top end of the throttle, not the bottom end.
Bruce
Old Aug 31, 2004 | 01:22 PM
DGpolaris2346's Avatar
If you have no mods 160 is way to rich go down to a 130 and it should solve your problem.
Old Aug 31, 2004 | 01:38 PM
tbsleeper's Avatar
exactly
Old Aug 31, 2004 | 02:08 PM
Thanks, it is stock, so I ordered a 130 main. I will hopefully be up and running in a couple days.
Old Aug 31, 2004 | 06:20 PM
Whitewater's Avatar
What color is your plug? It sounds too rich...have you adjusted the clip?
I've had the same problem with my sportsman 400 carb. I jetted down (150 for my elevation), installed a new main jet (40), installed a needle jet, jet needle, adjusted the air screw, and I raised the clip up 2 notches. The only problem I still have, is it doesn't want to start (cold) not without a pullstart. Damn thing...I give up. Other than that, it runs great (warm).[img]i/expressions/face-icon-small-disgusted.gif[/img]
Anyone have any advice?
Old Aug 31, 2004 | 06:26 PM
tbsleeper's Avatar
sounds like idoesnt have enough gas to start
Whitewater's Avatar
Maybe too lean?
Old Aug 31, 2004 | 08:10 PM
tbsleeper's Avatar
try turing the screw in and wen u go to start it have the choke out and be giving it gas see what that does.
