Trail Tech help
Old Aug 31, 2004 | 02:37 PM
SkoolBoy's Avatar
Default Trail Tech help
I installed the Trail Tech endurance on my raptor today and i cant get the spd to work...when i take off everything stays at 0...but when i stop and hit the backlight button it says i went 170mph...i have my settings correct i belive...and have it on m/s...wheel size at 1572mm ....i thought this thing wuold tell me the speed i was going right whern i was going it...any suggestion...
Old Aug 31, 2004 | 03:57 PM
Sandfox24's Avatar
Do you have the same settings programmed in for both bikes. Could the trail tech be set on bike 2 when the settings you put in are on bike 1?
Old Aug 31, 2004 | 04:38 PM
warwgn's Avatar
sound like you have a bad connection, make sure it clips all the way into the holder, then check the magnetic pick up and make sure it is correct. If you still got problems call Trail Tech. www.trailtech.org you can get the number from there.
Old Aug 31, 2004 | 06:01 PM
DGScrambler400's Avatar
i had the same problem..mine would randomly make up speeds. I called trail tech, and they said i had a bad cable, and they sent me a new one, free of charge. The new cable fixed the problem.
Call them, they have very good customer service, and they will help you fix it.
Old Aug 31, 2004 | 08:36 PM
AARaptor660's Avatar
How did you get the rotor off? Or did you have to? Skool Boy, will you please guide me how you got the magnet or bolt on
Old Aug 31, 2004 | 08:38 PM
you dont have to remove the rotor, you just need to glue a small magnet to the inside of the rotor
Old Aug 31, 2004 | 10:46 PM
SkoolBoy's Avatar
Didnt know you need to have bike 1 and 2 settings set..ill go try that..
AARaptor660
i removed basically everything....when i did this..theres 2 bolts that hold the claiper on, and one allen bolt..on the rotor i removed a rotor bolt with a socket allen, after stripping one with a t-handle this worked like a charm....get rid of the rotor protectant plate, and use their metal attachment that comes with the kit, there is where you plug in the sensor....
oliveiracarlos
19
Nov 11, 2015 05:49 AM
Brandon400
Sep 5, 2015 08:44 PM
JakeXBL
Sep 5, 2015 01:08 PM
Canamaniac!
Sep 4, 2015 06:44 PM
blueandy88
Aug 31, 2015 12:42 PM
